Stick Shift Question!!! PLZ READ!!!
Old Oct 16, 2005 | 10:06 AM
lilriceburner's Avatar
lilriceburner
>94' Civic Si Coupe
Default Stick Shift Question!!! PLZ READ!!!
I have a question...my buddy has a Celica GTS and when he uses his shifter it seems to like lock in place...its really cool...then he let me drive around and all the gears seemed to click in place...then i drive my 93 EG and the shifter is wobbly when its in neutral and i can never tell whether its in gear or not...the thing my buddy with the celica had, is that some type of click shifter, does anybody know the name of the thing im talking about cuz i really want one for my EG
Thanks
Old Oct 16, 2005 | 10:53 AM
1995Civic's Avatar
1995Civic
I hate ricers
First of all, if you have a 94 ex coupe, and your referring to the same car...thats not an EG.
Also, my guess would be that your buddy has a teptronic shifter for his celica, just like the RSX, CL, etc. Im not sure, but that is my closest guess. Is it an automatic but then you can also make it a manual? im a little confused on what you are trying to say.
Old Oct 16, 2005 | 10:59 AM
97civicEXVTEC's Avatar
97civicEXVTEC
did you install an aftermarket shifter in your car?? idk if your reffering to the play in the shifter, if you missed a bushing you will have a lot of play in your shifter and its harder to tell what gear your in..
Old Oct 16, 2005 | 11:02 AM
sherwood's Avatar
sherwood
I missed Sean
no he's reffering to how tthe bushing are. and how his shifter is mushy and his friends is crisp.
i've never driven a civic so i can't tellt he difference... but most likely it's just how the car is.. it migh be because your linkage is a little bit loose from age... that his shifter bushings might cause the car to click into gears....
Old Oct 16, 2005 | 11:03 AM
1995Civic's Avatar
1995Civic
I hate ricers
Oh ok...i was a little confused.
Old Oct 16, 2005 | 11:52 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
All hondas will "snick" into gear. If you have a 94 car the shifter bushings are probably bad and need to be replaced. It is a nice feeling
Autocross Help Page
Old Oct 16, 2005 | 06:28 PM
2gr84u's Avatar
2gr84u
2gr84u
15 dollars + energy suspension shift bushings = the shifter feel you want.
Old Oct 17, 2005 | 03:37 PM
alanMI88's Avatar
alanMI88
I hate to say it but...I had the same problem, replaced the bushings with energy suspension bushings, and it didnt do a thing.
Old Oct 17, 2005 | 05:00 PM
CivicSiRacer
Then the linkage could be bad too.
Autocross Help Page
Old Oct 17, 2005 | 05:04 PM
2gr84u's Avatar
2gr84u
2gr84u
most likly your problem wasnt just bushings then. I know my shift bushings made a big difference
