Big Help!! Help!!! Help!!!
Old Oct 13, 2005 | 01:27 PM
bambbrose's Avatar
bambbrose
check all fuses
Old Oct 13, 2005 | 01:37 PM
lilriceburner's Avatar
lilriceburner
>94' Civic Si Coupe
No check engine light at all..everythings seems to be fine...one thing i forgot to mention...the other day i removed my bumper to check my horn...i put and aftermarket one on correctly...and thats the last thing i remember doing before i had this problem
Old Oct 13, 2005 | 02:15 PM
lilriceburner
>94' Civic Si Coupe
PROBLEM SOLVED!! THANKS TO BAMBBROSE and some common sense...i should have thought about checking the fuses first. Turns out that when i changed my horn i blew a 20 amp fuse in the fuse box in the engine bay...now my horn AND my shifter and brake lights work
Old Oct 13, 2005 | 02:46 PM
bambbrose's Avatar
bambbrose
good to hear. BTW, there never was a SI coupe
Old Mar 5, 2011 | 08:20 PM
spitbawl's Avatar
spitbawl
Default My break lights wont work and my car will not shift out of park
I have a 2000 Acura TL. My break lights wont work and my car will not shift out of park. I can shift out of park by pressing the override button.
here is what I have tried/checked:
I checked all bulbs
I checked all fuses (driver side, passenger side, and under hood fuse box's)
I replaced the stoplight switch in brake arm
I adjusted the stoplight switch
I checked wiring in the tail lights and 3rd stoplight
what am i missing?
