cel 22 can this stop engine from starting?
Old Oct 1, 2005 | 04:25 PM
huge230's Avatar
huge230
Default cel 22 can this stop engine from starting?
i hsve never started my h22 in 95 civic and am only getting a cel 22 which is vtech pressure switch. dizzy seams good although i can get the plugs to spark. should i see them spark? im surprised only one CEL. any thoughts?
Old Oct 1, 2005 | 05:57 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Yes you should see them spark if there still hooked to the dizzy, lay them against the valve cover and see what happens. Also, you might have your firing order wrong. I did, the car wouldn't start.
Old Oct 1, 2005 | 08:26 PM
dubcac's Avatar
dubcac
I
The CEL22 will not prevent the car from starting, so your problem is elsewhere. If you can get the plugs to spark, then something else is wrong. Either you're not getting fuel, your firing order is wrong, or your timing belt possibly jumped a tooth or 2 on the cam gears...it could be lots of things.
Old Oct 2, 2005 | 03:10 AM
Civic2Scooby's Avatar
Civic2Scooby
also make sure when checkin for spark at the plug that it is grounded or else you wont see a spark.
Old Oct 2, 2005 | 03:19 AM
huge230's Avatar
huge230
how mnay grounds should there be? just 2 on the engine?
Old Oct 2, 2005 | 03:21 AM
Civic2Scooby
I mean the actual plug...the threads have to be touching a ground, any metal if it is just held in the air then it will not gap due to non grounding.
Old Oct 2, 2005 | 03:53 AM
huge230's Avatar
huge230
yes i knew what you meant but i was wondering if the whole engine isnt grounded enough it may be some of the problem.
Old Oct 2, 2005 | 04:17 AM
Civic2Scooby
oh..ok .....there would be a ground leading from the head to the chassis, and a ground leading from the trans. to the chassis as well. If they are corroded or not secured or prop. grounded, than it can have an effect on your ignition system.
Old Oct 2, 2005 | 04:28 AM
huge230's Avatar
huge230
thanks for your help. ill check my grounds
Old Oct 2, 2005 | 05:45 AM
huge230's Avatar
huge230
grounds are good and still nothing.
