tune up
I have a civic with 178000 miles and i dont think its ever been tuned up. what does a full tune up consist of and how much would it cost. and what is the best spark plugs for a civic and where can I get them for cheap? besides ebay
1. spark plugs
2. fuel filter
3. tranny flush
4. coolant flush
5. air filter
6. oil filter
7. oil change
8. lube all joints
9. rotate tires
10. brake fluid flush
11. brake pad change
12. brake rotor change
13. change the headlight bearings
2. fuel filter
3. tranny flush
4. coolant flush
5. air filter
6. oil filter
7. oil change
8. lube all joints
9. rotate tires
Autocross Help Page
Autocross Help Page
Originally Posted by flatliner
civic. dont forget the timing belt
heh
hehtiming belt is not considered a 'tune-up'..:squint:
changing the timing belt is a major job, and should not be attempted by someone who doesn't know what they are doing.
But, it probably does need changing. If your timing belt does break while you are driving, it can cause catastrophic engine damage. Honda recommends they be changed every 90,000 miles, but i've seen them go for much longer.
A shop will probably charge you $300+ in labor to do this job, just make sure they change your water pump at the same time because it is right there.
and if you are interested in doing the timing belt/water pump yourself, check out http://www.sicracing.com/info.html for a walkthrough.
