Timing belt & pulley removal question.
Old Aug 11, 2006 | 04:53 PM
fathergoat's Avatar
fathergoat
:3
the flywheel cover underneath by the oil pan.
Old Aug 11, 2006 | 04:59 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Get a huge braker bar and put it in reverse or in 5th gear and stomp o nthe brakes. Also, you can put a breaker bar in between the 2 wheel studs and have someone hold that too, that will completly stop the car from moving when u try to get it off. Also Spray it with some PB Blaster.
Old Aug 11, 2006 | 05:13 PM
OblivionLord's Avatar
OblivionLord
So inorder to get to the flywheel inorder to keep the engine locked .. you have to take off the transmission?
Old Aug 11, 2006 | 05:48 PM
fathergoat's Avatar
fathergoat
:3
no it's just a sheet metal cover on the bottom engine side of the tranny near the oil pan. 4 bolts and it's off.
Old Aug 11, 2006 | 06:02 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Use a chain wrench... and put a drove belt around the pulley, grip it tight and use a breaker bar with the 17mm socket...hold them in place an loosen that mofo. Have someone hold the chain wrench while you break that bolt loose.
Old Aug 11, 2006 | 07:07 PM
OblivionLord
i know what a grip chain is but what is a drove belt or are you saying drive belt because if you are then im thinking you mean to put the drive belt on the pully so the chain doesnt ruin the pully when tightened. Is that what your saying?
Old Aug 11, 2006 | 08:05 PM
sleezye's Avatar
sleezye
take it to a shop b\c it doesnt seem like u really comprehend things to well
Old Aug 11, 2006 | 11:45 PM
InfiniteVTec
The Dealer
the drive belt prevents both damage and slipping, metal to metal just won't grip.
Old Aug 12, 2006 | 12:27 AM
Civic2Scooby's Avatar
Civic2Scooby
everyone in here, its an auto...it doesnt have a flywheel..it has a flex plate, which is even weaker than than the teeth on the flywheel as it is thinner. DO NOT use it as a stopping point to remove the crank pulley.
Old Aug 12, 2006 | 05:18 AM
m735is's Avatar
m735is
Good catch on the (auto).
If you have $100 and time to wait a couple days, order the tool from Sir Tools. If you're doing a mini me swap now, you're probably going to use it again in the future. It also holds the crank while you tighten the bolt!
I've used mine on three motors this summer alone-BEST $100 I've spent. Makes this job painless!!
