Weak PoinT B20B @ 7psi ????????
Old Aug 29, 2005 | 04:30 AM
Techme06's Avatar
Techme06
Eg b20b turbo
Default Weak PoinT B20B @ 7psi ????????
just pop in a jdm b20b n running boost . wats going to give ?
eg b20 @7psi
jdm b16 tranny ls 5th
Msd
and a lame driver
Old Aug 29, 2005 | 06:13 AM
bambbrose's Avatar
bambbrose
the sleeves if you aren't tuned perfectly, next I would say the rod bearings, and third the ringlands
Old Aug 29, 2005 | 06:21 AM
lkailburn's Avatar
lkailburn
college kid
sleeves before the rods or pistons?
Old Aug 29, 2005 | 06:30 AM
bambbrose's Avatar
bambbrose
b20 sleeves are alot different than all other b series sleeves. I've seen them go at 8psi
Old Aug 29, 2005 | 06:31 AM
Techme06's Avatar
Techme06
Eg b20b turbo
i got a hondata . will that protect the sleeves ?
Old Aug 29, 2005 | 07:26 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
a good tune and no detonation
Old Aug 29, 2005 | 02:45 PM
bambbrose's Avatar
bambbrose
If you have a good tuner it'll help. Tuning is everything. personally i just say go for it, and when the bottom end lets out just resleeve it and you'll have potential for whatever
Old Aug 29, 2005 | 03:21 PM
Techme06's Avatar
Techme06
Eg b20b turbo
wat kinda power dose this motor put out at 7 psi . will it make girls clothing fly away ?
Old Aug 29, 2005 | 03:24 PM
sherwood's Avatar
sherwood
I missed Sean
in the right car it will, you'll have torue up the wazzo, girls love torque
Old Aug 29, 2005 | 04:15 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
The sleeves will go before anything else.
Yes, theyre the same sleeves as all b series engines...just 3mm thinner.
84mm vs 81mm
All you can do is get it tuned really well...and hope (or you could sleeve it and be done w/ it)
Just dont be surprised when it happens
