Weak PoinT B20B @ 7psi ????????
Old Aug 29, 2005 | 04:53 PM
Techme06's Avatar
Techme06
Eg b20b turbo
u think my motor will last to 100k ? it has about 32 k miles on it .just booted and only going to do 7 psi tops. planning to do alot of cross country trips with it. what do you guys think ?
Old Aug 29, 2005 | 04:55 PM
Techme06's Avatar
Techme06
Eg b20b turbo
Old Aug 29, 2005 | 04:57 PM
Techme06's Avatar
Techme06
Eg b20b turbo
ops my bad. pulled a double post
Old Aug 29, 2005 | 05:16 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
what fuel management?
what transmission?
what turbo?
Old Aug 29, 2005 | 05:48 PM
B18C Turbo's Avatar
B18C Turbo
put wings ont he side of the car, get it going to about 88mp and pull back onthe throttle, thing will lift right off and soar through the night sky
Old Aug 29, 2005 | 05:50 PM
Techme06's Avatar
Techme06
Eg b20b turbo
don't have a fms . just hondata ,b16 tranny,MSD ,stage 3 clutch , 12lb flywheel, and t3/t4 57 trim turbo
Old Aug 29, 2005 | 07:01 PM
bambbrose's Avatar
bambbrose
Originally Posted by PDiggityDogg
The sleeves will go before anything else.
Yes, theyre the same sleeves as all b series engines...just 3mm thinner.
84mm vs 81mm
All you can do is get it tuned really well...and hope (or you could sleeve it and be done w/ it)
Just dont be surprised when it happens
this is incorrect, they are the same thickness as all other B series sleeves, just a different siameese design casting for the b20. The casting has a tendency to crack along the seams between the cylinders. Contrary to most "internet forum" knowledge, the b20 ISN'T just a b18 with 84mm cylinders. Also, even if that was the case, you can't overbore the b18b clyinders more than 1 or 1.5mm anyways.
Old Aug 30, 2005 | 02:51 AM
Techme06's Avatar
Techme06
Eg b20b turbo
i had a friend tell me that once over 7k rpm my sleeves are going to blow . b18b turbo would have been a better chose for reliablity wouldn't it ?
Old Aug 30, 2005 | 04:13 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
torque and rpm kills sleeves...
Old Aug 30, 2005 | 07:30 AM
bambbrose's Avatar
bambbrose
Yes, ls's make good power and are reliable compared to the b20. I think the gsr is the best motor to boost period. it has stronger rods, better flowing head. not ridiculious compression, much much better rod and main bearings...etc
