engine build
Old Aug 24, 2005 | 05:54 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default engine build
i want to start building an engine.. i want to do a ls b18b an eventually turbo it.. what would i need to get to start making this engine.. i mean EVERYTHING.. thx
Old Aug 24, 2005 | 05:57 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
uuh
u wanna built it with new pistons and rods?
u should get
gasket set for the bottom and top
rod bearings
sleeveds bored and honed for a good piston seal
block decked
head resurfaced
new timing belt, water pump, oil pump,
some other shit but i dont feel like thinking
Old Aug 24, 2005 | 06:07 PM
B18C Turbo's Avatar
B18C Turbo
dont forget to replace the head bolts or use head studs. Replace every little hose you come across. You should replace the main bearings and the thrust washers as well. If you re-use the old rods, use ARP rod bolts, if not your forged rods will come with them. Honing is a must and boring only if scoring catches your finger nail. Always use new pistons rings and gaskets. You can get away with the old oil pump but mine as well do it now. Always replace the water pump, belt and tensioner. You don't need to get the block decked or the head milled if you remove them with proper sequence and use a MLS 3 layer head gasket with new bolts/studs. Use a precision straight edge anyways just in case make sure its accurate to .0002". And don't forget the factory book this is a must.
