Ls/vtec
Old Aug 20, 2005 | 07:42 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Originally Posted by 94JR
I was considering putting a GSR tranny on my LS. How much faster was it?
GSR has shorter gears then a ls. faster might not be the best word but it will be alittle bit quicker..
Old Aug 20, 2005 | 07:45 PM
IntegraType-R
ALL MOTOR KING
Originally Posted by Feelsgr82bealiv
Thank you for the advice. I have found full kits to make the conversion go more smoothly but if anybody can give me a little more help on where i can get more info regarding this operation. I will be stickin with the gsr tranny. Would it be better to fully build the block or leave it stock so i dont lose money when it blows.
To lead you in the right direct..
Mostly people use the b18b blocks.. and b16 heads.. if u have a gsr head use it.. but cheap way is b16 head.
Mostly people leave them stock and run roughly everything stock.. but some upgrades you might wanan think about are the following.
Rod bolts
head studs
injectors
ecu
basically its justa bolt on project golden eagle sells a ls/vtec conversion kit for around 100 bucks to do the whole oil process on the vtec head..
i'd highly suggest looking at honda-tech for some of their build ups and make sure you know where you wanna go with this.. doing ls/vtec 90% of the time means your going all motor.
IntegraType-R
ALL MOTOR KING
But i already heard that these motors are unreliable so i really dont want to add a turbo. would the gsr tranny still be the way to go.
completely wrong.. any motor can be unrealibly if it isn't taken care of..
Old Aug 21, 2005 | 08:16 AM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
Any thing CAN be unreliable, but if you do an ls vtec and get the proper set up and tunning job it could be just as reliable if not more than a b16. Its all in what you use and how it's tuned. Over all i hear GREAT things about them...
Old Aug 21, 2005 | 11:23 AM
Feelsgr82bealiv's Avatar
Feelsgr82bealiv
I had a friend that had an ls/vtec and he said the best way to go is stock parts all the way because they are cheap to replace but he blew his first motor 250 miles into it and he hadn't even broke it in and on top of that he wasnt even ragging it out, the second third fourth and fifth motor didnt turn out too different except his sixth motor which he added a turbo to lasted him a good four months before he blew it at a red light not doing anything except waiting for the light to turn green. So thats why i want to BUILD the thing right. that also how i know these things are not reliable unless fully built.
