Making Auto Stonger!!!
Old Aug 9, 2005 | 09:09 AM
Joshcivic00's Avatar
Joshcivic00
Default Making Auto Stonger!!!
Down the road i am planning on getting a levelten automatic transission upgrade for my 2000 Civic EX with 125,000 miles running 5lbs of boost on a greddy kit(planning on raising boost)!i was just wondering on what level ten parts ill need to get??? i am wanting to run maybe 10-12psi tops(after rebuilding engine)!
Old Aug 9, 2005 | 09:36 AM
Jafro's Avatar
Jafro
I'm made of meat!
Get the shift kit (valve body modification), and a torque converter upgrade. I can't imagine there's much of anything else that you'll need to make it shift better and slip less.
Old Aug 9, 2005 | 11:52 AM
95 SOL's Avatar
95 SOL
Banned
Higher stall Torque converter, new clutch packs, shift kit, possibly a new valve body. Not worth it IMO might as well convert to manual. I've beefed up an automatic before and it still wouldn't hold as much power as manual trans will.
Old Aug 9, 2005 | 12:00 PM
94civicEX's Avatar
94civicEX
I got worms.
Switch to manual and worry about a clutch.
99 Integra GSR
06 TSX
duck squad member #00003
Old Aug 9, 2005 | 02:10 PM
Joshcivic00
how much would a conversion cost roughly???(what will have to be switched out???just the tranny???)and cant u find EX manual transmissions pretty cheap???
Old Aug 9, 2005 | 02:12 PM
95 SOL's Avatar
95 SOL
Banned
You need tranny, shifter, shifter cables, pedals, trans mounts...think that's it. Not sure on the cost i only converted DSM's so i'm not sure about honda's.
Old Aug 9, 2005 | 02:20 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
you forgot the linkage also. and maybe a manual ECU?
Old Aug 9, 2005 | 02:27 PM
Joshcivic00
well here is my basic question!If i rebuild my auto transmission with the right stuff will it be able to handle 9-10lbs of boost safely???(it is a daily driver so i dont give it WOT much if at all)i just dont want to have to convert to manual if i dont have to(by properly rebuilding auto tranny)
Old Aug 9, 2005 | 02:49 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
it will never be as strong as a manual one. just save yourself the money and troube and swap for a 5spd.
Old Aug 9, 2005 | 03:14 PM
ewood87's Avatar
ewood87
Eric Wood
swappin in a manual will probably be the same if not cheaper than beefing up the auto..
