Need help checking a car...
I found clean virgin 92' Si with 86,000 org. miles.
I ran a Carfax and it pops up clean but it shows regristaion every year up till 1997.Shouldnt every year be on the Carfax up until 2005?
It was a 2 owner.Bought in SC and then a guy in Georgia owned it.
How can tell if it sat for along time?
If it did sit it was in a garage.The weatherstiping and everything are in really good condition.
Thanks
Thanks
i purchased my civic used. the carfax said it was a lease car with clean title.. after i bought it, i found out that it's been in an accident twice. luckily if there was frame damage, it's been properly fixed.. i had it checked. also it was hard as heck to turn.. after inspecting the front suspension, i found that the caster was negative on one side.. i took it apart to find an integra lower control arm on the driver side.. sheeesh..
using carfax is better than nothing, but i wouldn't judge your decision on it. find someone that knows the field and have them take a look at the car for you. example: my friend is a used car salesman.. he goes to all the auctions. he can take a look at a car and tell you if it's been in an accident, if the frame is straight, or even if the car's been repainted. just by walking around the car once.
FYI: Most of Georgia doesn't require safety inspection or emissions checks. The vehicles' mileage won't be recorded unless it changes ownership, so it's likely that you'll find nothing from the GA owner unless it was wrecked and the cops came out to file a report.
Originally Posted by P()()RB@Y
I knwo whats up with states like Georgia and Arkansas thta dont require inspection?
Is there anyway to tell the actual milage on a car or motor, if the odometer had been swapped?
P
R
N
D
D2
D3
D4
... going through the middle of it, my guess is the cluster could have been changed (either that or the transmission has). But if the cluster gets changed, it doesn't necessarily mean the mileage is wrong.
A rusted out undercarriage in GA on a car with 86k miles is unusual (if it's there). They don't get much snow or ice at all, and they never salt the roads when they do. At least not like they do in VA and states north of there.
If the rubber texture on the pedals is worn smooth, chances are it has a lot more than 80k miles on it.
If lots of little plastic parts throughout the interior are cracked or broken, chances are it's got more than 86k miles on it.
How many new parts are on the car? It shouldn't need its first timing belt until 90k. Has it been changed? If not, the mileage is most likely accurate. If so, how long ago? If it were changed pre-maturely, it may have suffered some engine damage or been in an accident... but there are other easy ways to determine that. Like...
Is there any overspray in the wheel wells, radiator or on the suspension parts on the underside of the car?
Look for "tool prints" on bolt heads and screws that signify that someone has taken them loose before. A "tool print" is a mark left by a mechanic. They come in 3 forms. 1) rounded off bolt corners 2) stripped screws 3) broken paint marks that the factory leaves on some bolts to mark their torque. You gotta know your shit to find #3.
It's not unusual to find low mile cars. My GF had a '94 Ford Probe with 60k on it. It's totalled now, but that's an uncommon find. I've been finding '95 GSX's in my area lately with 60k on them. Garage queens. You can find them.
