terms
Old Aug 8, 2005 | 08:39 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default terms
yea im a noob its my first year gettin into cars so i just want to know if anyone can clear some of the terms for me (be gentle)
head
long block
OBD
OBD2
DIY
Old Aug 8, 2005 | 08:54 PM
JoshJ's Avatar
JoshJ
bang bang.
OBD= On board diagnostics
DIY=Do it yourself
Old Aug 8, 2005 | 09:21 PM
extensioncordy's Avatar
extensioncordy
EG6
head is where gas/air enters and exhaust leaves...what your header bolts too
long block is complete motor without tranny block and head short blocks are without head
Old Aug 8, 2005 | 09:22 PM
extensioncordy
EG6
92-95civic i kno are obd1 and 96-? is obd2
Old Aug 9, 2005 | 05:00 AM
Jafro's Avatar
Jafro
I'm made of meat!
head=cylinder head. It bolts to the top of your block. It's the thing that contains your valvetrain and cams, and it's like the lid on your engine. It holds all the explosions in.
Old Aug 9, 2005 | 11:44 AM
95 SOL's Avatar
95 SOL
Banned
head = refering to the cylinder head on the engine.
http://catalog.roversnorth.com/catal...r%20head13.jpg
long block = like stated is the block and the head complete minus the tranny.
http://www.revolutionaryperformance....ck%20photo.jpg
OBD = Is "on board diagnostics" version on cars previous to 1995.
OBD2 = All cars built since January 1, 1996 have OBD-II systems. Manufacturers started incorporating OBD-II in various models as early as 1994. Some early OBD-II cars were not 100% compliant.
here's a pic of the connector. where you plug in the scanner to pull codes and information from the car's computer.
DIY = Do it yourself. When you want to know how you can perform tasks like making a custom grill insert...that would be a DIY.
Old Apr 20, 2006 | 12:41 PM
adam420's Avatar
adam420
where is the diagnostic plug on a 1993 honda civic
Old Apr 20, 2006 | 01:04 PM
Kai's Avatar
Kai
Rotorphile.
There is no standard OBD2 plug on pre-96 Civics. You can short the SCS connector behind the passenger's kick panel with the proper jumper or a peice of wire. Once shorted, the check engine light will blink the error code.
There is a non-standard diagnostic plug in the car, but you will need an adapter and a $200+ scanner to use it.
