Why is it (tires)?
Old Aug 30, 2005 | 03:34 AM
Techme06's Avatar
Techme06
Eg b20b turbo
i have slipstream 15x6.5 with 225/50/15 falken Ziens 175/60/15 back . the fronts , they fit find . they don't tuch my walls and bearly tuches my plastic water gaurd . U-turn are no problems . i lifted the car and tested on my civic eg 93 . non dropped , my car looks drip but cuz teh wheels are so big but the high is bad. these tires grip hard - good for snow trips and fast lanch.
Old Aug 30, 2005 | 09:32 AM
Wharbone's Avatar
Wharbone
Wouldn't you want smaller tires to cut through snow? 225's seem a bit wide, especially for snow use.
Old Aug 30, 2005 | 10:59 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
depends on offset and width of tire and rim.
205 is the safest with the 2.0+ inch drops that are common with Honda folks nowadays.
Old Aug 30, 2005 | 11:13 AM
VSLOATHE's Avatar
VSLOATHE
I got the SPC shortened rear LCAs so that I wouldn't have any tire rub in the back. I occassionally rub in the front, but that's due to the fact that there are a lot of bumpy roads around my area and my bump stops are still in the mail h:
Old Aug 30, 2005 | 02:05 PM
cbags05's Avatar
cbags05
Oh...He-rr-o
Very informative thread...thanks guys.
Old Aug 30, 2005 | 02:27 PM
cbags05's Avatar
cbags05
Oh...He-rr-o
Ok so let me get this straight. Right now I drive on the stock sized 185/65-15" (24.5 ID). On track days when I switch to 205/50-15" (23 ID) I will reduce the size of the "gear". My car will accelerate faster? Or it will appear so on the speedo? Or both...
Old Aug 30, 2005 | 03:37 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Yes in a sense it should. Your speedo will be off by alot. Going from 24.5 diameter to 23" is a significant difference.
Autocross Help Page
Old Aug 31, 2005 | 07:32 AM
Techme06's Avatar
Techme06
Eg b20b turbo
your right . but i'll have snow chains on . 93 civic with only one airbag in the snow is scary as hell . haha but you are correct about that through snow.
