Why is it (tires)?
Old Aug 4, 2005 | 07:30 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
My Ziex's have the same 'lip protector'.
Thanks, Mike. Any noticable difference on the track or did you run them there?
Old Aug 5, 2005 | 10:30 AM
96GreenCivic's Avatar
96GreenCivic
I just got my Ziex's as well and the lip protector is nice, but I preferred the overall look of my Toyos vs. these Falkens. But the Falkens were a lot cheaper.
Old Aug 5, 2005 | 10:33 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Well you stay in the meatier part of the power band for most courses. But I remember on the larger courses I would redline.
Autocross Help Page
Old Aug 5, 2005 | 10:42 AM
westcoaststyle
Interesting. Thanks again.
Old Aug 5, 2005 | 12:20 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Originally Posted by CivicSiRacer
At 80mph I was going 5000-5500rpms. Annoying! I didn't have any rubbing issues when I ran 215/40x16" with 16x7.5" rims back in 2000-2001.
I'm curious as to how the tire size changed your gearing.
Old Aug 5, 2005 | 01:26 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I have 195's. I just always figured 215 would be bad for my fender well.
Old Aug 5, 2005 | 05:40 PM
CivicSiRacer
It's like the cogs on your mountain bike. Stay on the smallest front ring and largest rear ring and you are pedaling super fast. Then stay on the largest front ring and smallest rear ring and you can barely make it up hills.
What you want for daily street driving is keeping the overall diameter tire size the same as stock. Remember your tires and wheels are like gears since they are part of the transmission. Let say you have 195/55x15" (overall diameter is 23.4" and tread width is 6.8") tires like they came on my 00 Civic Si. If I wanted to "+1 PLUS SIZE" my tires I would go up to 205/45x16". "+2 PLUS SIZE" would be 215/35x17" but there is no such size so I have to use 205/40x17" (23.6") which is 1/4" larger than stock. This in turn makes the car accelerate a bit slower since it increases my gear a bit. On the highway if your speedo says you are going 65mph then you would be going 67mph according to the police. Very minor. Also your mpg suffers because your car has a higher gear (in a sense) and takes more energy to turn the wheel to get you going. Sort of like starting off in 2nd instead of 1st.
But you don't have to follow the recommended PLUS SIZING. Like most guys do we run 205/50x15" which is like 1/4" shorter than stock and tread width is 7.3". So it gives a bit better acceleration but doesn't really throw off the speedo by much. Say you are going 65mph the cop will clock you going 63mph. It's wider than stock so you have better cornering grip.
If you really want to widen your track you could use a 215/40x16" (overall diameter is 22.7"), so the tire is very short but wider (tread width is 7.8") So you gained about 1" width, which makes a HUGE difference in cornering, but now you are 3/4" shorter in height. So at 65mph your speedo will read 75mph or so. I remember asking my friend when I pulled along side him and he was going 80mph and my speedo read 90mph! And my rpms were like 5500rpms with an N1 exhaust.
So there you go
Autocross Help Page
Old Aug 5, 2005 | 05:48 PM
delsol161's Avatar
delsol161
275s would prolly never fit on any honda would they? hehe
Old Aug 5, 2005 | 06:51 PM
CivicSiRacer
I've seen it done. But you need 13x8" wheels and really stiff springs. Also need 275/45x13" tires
Autocross Help Page
Old Aug 7, 2005 | 12:50 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
good luck with that...
