1992 Civic lighting problem, headlights work but nothing else does
Old Aug 3, 2005 | 10:09 AM
vtecvu's Avatar
vtecvu
Default 1992 Civic lighting problem, headlights work but nothing else does
Hey guys im having a problem with my 92 civic four door, my headlights turn on but my taillights, parking lights and dash lights dont work, my brake lights work fine, please help me.
Old Aug 3, 2005 | 10:10 AM
Running925's Avatar
Running925
Your Powder Coater
check the fuses under your dash!
If you look at the resourse sticky in the Civic section, it will have the diagram for you so u know exactly which fuse to check!
*edit.. heres the link
http://www.honda.co.uk/owner/civicManual/index.html
Old Aug 3, 2005 | 10:23 AM
vtecvu's Avatar
vtecvu
Ok, so i checked out the fusebox, cause the damn thing didnt have a diagram on the fusebox cover, i found the dashlight fuse, and it was busted. so i put in a new one and as soon as i turn on the parking lights it blows, i went thru 3 fuses. Does anyone out there know what my problem is? my taillight fuse was fine, not blown, but still dont work. thanks
Old Aug 3, 2005 | 10:44 AM
Running925's Avatar
Running925
Your Powder Coater
u probly have a wire grounding it self out on metal somewhre.. dealing with your parking lights.
Old Aug 3, 2005 | 11:27 AM
dspencer24's Avatar
dspencer24
b18c ftw
check to see if water got in there and is still in there! try your bulbs start at the easy point first. you started at the fuse box, so now you now its somewhere in between the panel and the light? maybe the boot wasnt on correctly before? do you have a mulitmeter? if so start checking your plugs to ground if you ohms are less then one mega ohm/ or you have continuity then you prolly have a gound somewhere!!
Old Aug 4, 2005 | 04:14 PM
vtecvu's Avatar
vtecvu
This car did go thru a huge puddle and suck up water. I installed a new motor and everything went fine for a few weeks then all of the sudden no lights. has anybody heard anything about it maybe being a multiplex unit? thanks guys
Old Aug 10, 2005 | 12:39 AM
vtecvu's Avatar
vtecvu
can anybody help me, checked all wires no wire touchin metal anywhere
Old Aug 10, 2005 | 11:23 AM
dspencer24's Avatar
dspencer24
b18c ftw
were you usin gthe right size and kinda fuse? i know its a dumb question ?
Old Aug 11, 2005 | 01:47 PM
derekdunham's Avatar
derekdunham
that should be a 10amp fuse.
