broken hood popper (plastic)...
Originally posted by fujiwara takumi
on my s10 the cable was crimped on, there was no way to do one or the other, you had to do both...
i actualyl had snapped the cable in the engine bay, so i had to learn to open the hood with a vice grips, what a pain. the new part was $35.
btw, it is so un-****ing believably easy...paying $87 is a joke.
Originally posted by TheBigDog
Takumi, so did you end up fixing the cable yourself or are you still using the vice grip? just curious cuz' I was told that it is hard to isntall that.
i just cut all the plastic off mine and then took a die to the shaft that was inside the plastic. i don't remember the size of the die for sure i think it was 6mm x 100pitch. then i got a nut and a washer and put them on it. works great, costs all of 40 cents
Thanks in advance.
