b16a 2 into civic dx/cx/ls/si
Old Jul 19, 2005 | 03:29 PM
madman4you's Avatar
madman4you
Default b16a 2 into civic dx/cx/ls/si
quick question. i was wondering is civic dx the only civic that requires more work when doing a swap? i know an si you only need to wire up v-tech but on my 90 civic dx there was only the dual injection so we had to screw around with wiring the injectors. just want to know if all the other models are just as easy as si. and does it make a different if its 92-95 models.
im just trying to see how easy it is to do a b16a 2 swap is in a 92-95 cx. i know there is going to be replies such as: "use the search button" but i did and came up sort. so please just let me know.
Old Jul 19, 2005 | 03:50 PM
VTEC-Power's Avatar
VTEC-Power
you still need the use your existing wiring harness to splice and cut cables
Old Jul 19, 2005 | 08:06 PM
Paul's Avatar
Paul
Eater of Rice
wow, have you done this swap? because you don't have to splice cables, you don't have to cut cables, you add a few wires.
Old Jul 20, 2005 | 06:04 AM
madman4you's Avatar
madman4you
do you just add the 4 wires. too hooke up v-tech and what ever else is needed.
Old Jul 20, 2005 | 06:32 AM
When I hooked up my vtech I plugged the power cord into the wall outlet and the phone cord into the phone jack.
Old Jul 20, 2005 | 06:51 AM
goon54's Avatar
goon54
idiot.. qutoe napoloen dynamite
Old Jul 20, 2005 | 12:12 PM
Omniscient's Avatar
Omniscient
warm butter on toast
He might have to lengthen the o2 sensor wire because its all the way back near the cat.
Old Jul 20, 2005 | 07:43 PM
Paul's Avatar
Paul
Eater of Rice
Good point, or you can just disable it with uberdata.
Old Jul 21, 2005 | 09:36 AM
madman4you's Avatar
madman4you
thanks guys
