jdm ctr red carpet
Old Sep 2, 2002 | 10:26 AM
  #31
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Originally posted by knight0118
first off....a itr swaped hatch can run high 13s in stock form seen it done many times....2nd a itr dyno yeilds about 172whp stock...3rd the money it would take to build a b20turbo on 10psi would be wayyyy over 5grand....
we aren't talking about a swapped 2000 pound hatch, we're talking about a 2500 pound coupe. You will NEVER hit a high 13 with just a itr/ctr swap in your car. I doubt you can even pull a low 14, a stock ITR doesn't even pull a low 14, what makes you think the motor in your coupe is going to be any better. In any case i doubt a STOCK itr dynoes 172 whp. A stock obd 1 gsr only dynos about 140. And 3rd you are just a retard if it costs you more than 5 grand to put together a b20 turbo setup. A b20 motor should cost you maybe 1300, a gsr tranny for 700. That's 2000+3000 for a revhard/drag 3/fmax turbo kit. And don't even try and tell me a stock b20 won't hold 10 psi stock.
Old Sep 2, 2002 | 10:27 AM
  #32
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
http://www.autostyles.com/hondcarp.htm
Old Sep 2, 2002 | 10:58 AM
  #33
knight0118's Avatar
knight0118
i thought u were refering to a hatch...anyhow stock itr whp is 170+ all the time...here is a dyno hitting 176 all stock
and if u think a b20 can run 10psi u just go ahead and do it because that is just stupid...and the whole ****n! point of this thread is that i am going jdm itr motor fits the jdm class a little more than a b20 foo...maybe someday ill take itr and build it for turbo...
Old Sep 2, 2002 | 11:01 AM
  #34
crucial Si's Avatar
crucial Si
Banned
there is no way a ctr, itr motor in a usdm civic will hit anywhere near low-mid13s...sh!t i bet it wont even do high 13s...i would say low 14s.
Old Sep 2, 2002 | 11:02 AM
  #35
knight0118's Avatar
knight0118
no one said it would i was refering to a hatch not a coupe
Old Sep 2, 2002 | 11:26 AM
  #36
Jkan2001's Avatar
Jkan2001
S2000 Pilot
I wasn't talking about JDM class...i could really care less about jdm...if that's your cup of tea, go for it. But someone said that a CTR motor in a coupe would be fast and i was just saying for the money you could be WAY faster. And yes b20 can handle 10 psi easily....hell a bunch of sohc ppl are running 10 psi with good fuel tuning. Do some research before you post.....cause evidentily you think 250+ whp is "stupid" probably cause it isn't JDM
Old Sep 2, 2002 | 11:29 AM
  #37
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Even in a 2100 pound hatch you wouldn't be able to hit a low 13. I'd say a mid to high 13 at best....
I agree with crucialSI
In a coupe you'd be lucky to hit a low 14
Old Sep 2, 2002 | 11:37 AM
  #38
crucial Si's Avatar
crucial Si
Banned
even in a h/b youd run a low 14 if they do high 14s in there "original" car WTF is so special after you swap it into your US car.....nothing.
Old Sep 2, 2002 | 11:39 AM
  #39
Jkan2001's Avatar
Jkan2001
S2000 Pilot
well that's not true....i think a itr is over 2500 pounds cause a gsr is like 2600-2700 i think. When you stick the motor in a 2000-2100 pound gutted hatch that will make a big power to weight ratio difference which is why i said a mid to high 13 at best instead of a low 14.
Old Sep 2, 2002 | 11:42 AM
  #40
crucial Si's Avatar
crucial Si
Banned
im not talking about a gutted car. im just saying swiching motors from the japan counterpart wont do sh!t for you except to run the same as them..(b16b in a 6th gen HB)
if you are worried about 1/4 times build an LS/vtec..can get into the high 13s with little work and alot cheaper than a b16b by a long shot
