BARO sensor problems on my 98 ex
Old May 20, 2005 | 09:43 PM
eonsx311's Avatar
eonsx311
today is not my birthday.
Default BARO sensor problems on my 98 ex
error code came up as BARO sensor. anyone know what one looks like and where i could pick one up. couldnt find one on the web anywhere.
Old May 21, 2005 | 05:58 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
the baro sensor on most newer Hondas are located inside the ecu. Now the bad news is you can't replace it without replacing the computer. It's lame but that's the way to fix it. I have three or four computers with bad baro's at work just for testing other systems. It's not uncommon. Try ebay for one or a local dismantler. I'm sure a new one is around 800 or so..
Old May 22, 2005 | 10:17 AM
FATHONDA's Avatar
FATHONDA
Default how techie are you
if you are not scared you can open up the can of worms called an ECU and with air in a can( from computer stored, clean the small sensor and board.
Old May 22, 2005 | 05:51 PM
eonsx311's Avatar
eonsx311
yeah, ill open the can of worms. so are you sure the air cleaning method will work? should i buy some electronics cleaner, the kind that evaporates? i cleaned a cell phone that got salt water in it and got it to work again so im asuming that might do the trick.
Old May 24, 2005 | 07:20 PM
FATHONDA's Avatar
FATHONDA
Default air in a can
I have done this one only one ecm with the pressure sens in the computer, it was a noo loose basis. it worked though.
Old May 28, 2005 | 08:31 PM
hondatech's Avatar
hondatech
:bs: It's a logic function inside the computer that detemines the ambient pressure not a sensor inside the ECU...
Old May 28, 2005 | 08:34 PM
FATHONDA's Avatar
FATHONDA
so it just says o here is my cfm? no. its a map setup not maf? Like my acuras baro sensor went out and even the dealer was dumbfounded/
Old Jul 3, 2005 | 03:28 PM
hondatech's Avatar
hondatech
ok whatever then, believe what you want I'm growing tired of explaining
Old Jul 3, 2005 | 05:27 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Hondatech is correct. I looked it up.
