D16z6
Old May 16, 2005 | 04:53 AM
mistacee's Avatar
mistacee
Zc powered ED9
All these questions which can EASILY be searched for...
maybe you shouldn't be swapping anything since you can't work a simple search.None of this stuff you are asking is new or groundbreaking.All of it can be found and has been gone over many times!
Old May 16, 2005 | 01:56 PM
AliasNeo's Avatar
AliasNeo
wow what a jackass.... i can work a search and i have searched couple of times but its all coming up as b series if that.... i came here to learn, its my first car and stuff... people learn by asking questions
up until u came along in this thread it was going fine... u just had to be the jackass to say that...
sure ive never swapped a car engine before... but im learning bout it, so stop being a shitface and and answer the question or not post at all...
i think this place is going on a downfall with people being dicks like you not answering a simple question... in the time u typed that u prolly or someone else could have answered the question...
same thing with the guy asking for oil change in a 97 some jack ass said "85w140" wtf can he just not make the one who answered the question easier by answering it...
now my rant is done id like to thank the others that have HELPED me so far
Old May 16, 2005 | 03:35 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
wow, welcome to HAN, I can see you will get along fine with all of the other Bi-Polar people here....
If you want answers you have to ignore the people that dont answer your questions, and not reply with "shitface", "jackass", "dicks", and I think "prolly" might be a bad one also, but im not sure what it means?
Just calm down, the questions that you asked have been asked 1000 times befor, like he said, do a search, you will find alot of info on the B series swaps, and H series swaps.
If you want to do a Z6 swap then all the info you need is:Technically, putting a Z6 in an OBD2 car (96+) is illegal. You are supposed to only swap motors that are of the same or newer year than the car they are going into. That said, the Z6 will work just fine, but you will need to get an OBD2 (a in this case) to OBD1 conversion harness and then find a P28 ECU to run the motor since the OBD2a ECU will no longer be compatible with your setup.
www.google.com ....
Old May 16, 2005 | 04:59 PM
mistacee's Avatar
mistacee
Zc powered ED9
Ohh boy!
Old May 16, 2005 | 05:00 PM
mistacee's Avatar
mistacee
Zc powered ED9
You my friend are just as much retarded as i am a jackass then.
Your not searching correctly.Again all these ?'s have been asked before.Search this board,H-T,hondaswap,etc...
To be honest,this is how i learned when i got into this stuff 5+ yrs ago...
I didn't come on boards asking every question out there,i searched and read and did my own research and there was even less info out there when i started.So with the plethora of resources out there now, it should not be hard for you to find info. Why must every noob have there hand held?
Old May 16, 2005 | 05:37 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Somehow I got away with asking questions like this haha. But, I stopped crawling, now I know how to walk. Thank you HAN!
Old May 17, 2005 | 05:36 PM
AliasNeo's Avatar
AliasNeo
... i did search for this, but as i was looking into the d16z6 and a the b16 i found a h series motor... i wanted to know how much harder it is to fit the motor in then a b16 or any b series motor and what is needed differently....
personally if i knew you in person and you called me retarded you prolly would have a fucked up face, cause i so ffended being called retarded and shit like that, cause i for one do have a disability... only reason i called you a jackass is because all the shit going on round here bout people asking simple questions and simply not getting answered the way they want... instead they take bout the same ammount of time to right a post on how to search then just answering the question... who gives a shit if its been asked before... i mean seriously, they come for help and u turn ur ass on them telling them "SEARCH" and you just added to that group
ive never had the opportunity to open up cars and their engines and just sit there... i do not have the space or tools to just sit around like that...
Old May 17, 2005 | 08:31 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
simma simma h:
You ladies need to quit bickering. Move along with the topic...
