help..
Old May 9, 2005 | 05:14 AM
black4string's Avatar
black4string
Default help..
im about to buy a gsr engine, and have someone install iton my eg...
what are the things i need to check and replace in the engine before they put it in the car.. i mean, like the water pump, i read somewhere that i have to replace it...
can someone post pics of the things i need to check and replace if they are broken or missing, like the sensors and stuff and pics of the things i need for the swap....
thanks..
Old May 9, 2005 | 11:44 PM
black4string
i need help..
there is this guy in the place for the swap, telling me i have to replace the fuel tank..
thets what he told me, i asked why.. he said, "supposing your car is a hatchback, we have to replace the gas tank.." after that he said something bout carb.... i dunno what that means, carburated? is there a carburated eg?
by the way.. this is in the philippines...
Old May 10, 2005 | 12:04 AM
u dont have to replace the gas tank... that guy is a douche.... take it to another place
when u get the engine, i would suggest new clutch/fly combo... they are used engines, u cant really be too sure if the fly/clutch combo was broken in properly *300-500miles* water pump, dizzy, plugs/sparks....sure there is more i cant think of any right now though... ill edit as soon as i remember
Old May 10, 2005 | 11:37 PM
black4string
thanks dude.... after all the reaserch done in this site and in h-t..
i thought he was b.s.
thanks..
Old May 10, 2005 | 11:39 PM
Civic2Scooby's Avatar
Civic2Scooby
I would do timing belt timing belt tensioner, water pump, check the dizzy, spark plugs, plug wires.
Old May 10, 2005 | 11:46 PM
what he said, i totally forgot i said i was going to edit, belts like he said just popped into my mind....
Old May 10, 2005 | 11:49 PM
Civic2Scooby
oh...also I replaced all heater hoses and vaccum lines while the engine was out, along with PCV valve. oh..and thermostat isnt a bad idea either
Old May 10, 2005 | 11:58 PM
dude, you were thorough i think on all my swaps i half-assed it looking at what you replaced i think all i did was the belts, dizzy, clutch/fly, spark/plugs wires, water pump, and i think thats it....
then again most of that stuff looked good but figured might as well
Old May 11, 2005 | 12:39 AM
Civic2Scooby
well I had about two weeks with the motor just sittin in my garage on my work bench....so I got bored and started replacing every damn thing I could find that wasnt brand new....h:
Old May 11, 2005 | 06:08 AM
mistacee's Avatar
mistacee
Zc powered ED9
Originally Posted by black4string
i need help..
Based on that,you prob should do more research b4 you bought your swap.
Why do ppl rush into these things??
