Brake Upgrade?
Old May 12, 2005 | 05:52 PM
  #31
delsoldude's Avatar
delsoldude
del Sol VTEC front brakes are a little larger. they are 10.somethin as most of the rest of the Honda's are 9.somethin. the rears are all the same. Unless you want to go 5 lug with the Teg Type-R
Old May 12, 2005 | 06:35 PM
  #32
racerdave's Avatar
racerdave
USAF C-17 Crewchief
I just got new 4 lug wheels, so no I dont want to go 5 lug.
So if I want larger front disks I can get them off of a (what year) Del Sol VTEC?
Also, will this front caliper/disk conversion just bolt up?
Old May 12, 2005 | 06:40 PM
  #33
oscar_425's Avatar
oscar_425
Got V-TEC??
I know the teggy brakes will be a direct bolt on...
Old May 12, 2005 | 06:45 PM
  #34
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Ok, but are they 4 or 5 lug, and whats the difference between them and the ones that I have?
Also what year is everyone talkin about here? I need to know year, and model.....
Old May 12, 2005 | 07:20 PM
  #35
oscar_425's Avatar
oscar_425
Got V-TEC??
all teggy and civic brakes in the US are 4 lug except for Civic/Integra type Rs that are 5 lug
Old May 13, 2005 | 10:52 AM
  #36
delsoldude's Avatar
delsoldude
They should bolt right up. The Years are, 94-97 VTEC models only. the size is 10.44. That should be the most you will need for even spirited drivin. Those along with good pads a rotors will do you just fine
Old May 13, 2005 | 11:42 AM
  #37
eonsx311's Avatar
eonsx311
today is not my birthday.
powerslot sloted rotors and axxis kevlar metalic pads= good setup
my friend tim has an 05 rsx type s and we went for a ride in my car after i did the breaks. i wanted to show him how well they stopped so i kept speed like i was going to go by his street and stepped on them hard. he couldnt believe that was all i had done to get the car to stop like that. he said it wasnt too far off from how quick his rsx stopped. i let him try it and he was still amazed. one BIG problem tho. slotted rotors have a tendency to warp if you have a sticky caliper, and you wont even notice untill you rotate the tires. the warpage gets so much worse when you dis-seat them off the rim they were warped on. check those calipers before purchasing slotted. just my 2 cents.
