Brake Upgrade?
rusty and ugly doesn't affect brake performance
h:
If your rotors are within spec, they're fine, despite rust. If you want to replace them anyway (just for looks) brembo blanks or any other comperable blank OEM reproduction rotor will do just fine. You can then spray them with high temp paint to ensure that the part of the rotor not in contact with the pads wont get rusty.
If you're looking for performance upgrades, a set of quality brake pads will go a long way.
h:If your rotors are within spec, they're fine, despite rust. If you want to replace them anyway (just for looks) brembo blanks or any other comperable blank OEM reproduction rotor will do just fine. You can then spray them with high temp paint to ensure that the part of the rotor not in contact with the pads wont get rusty.
Originally Posted by PDiggityDogg
Who says it does?
Originally Posted by Shmoo
He said he wants to save some money, so why would you recommend stainless steel brake lines? Unless road racing, the brakes don't get hot enough to need steel lines, so why would he waste his time and money buying and installing something he doesn't need?
If you want to be an ass and nitpick my response, why not jump on the mc/bb combo as well, since its all for feel also?
lines aren't necessarily "just for feel." They also reduce fade when brake temps get really high.
Whoopity doo. Thats a choice he can make on his own...I only put in what I did. I NEVER said that it would up braking performance.
That is great that you wasted $100 and your time to install them for a stiffer pedal, but for a person on a budget, you shouldn't recommend parts that don't do anything except make their wallets lighter and their time wasted since their application will not take advantage of them.
As for the original thread creator, just get a good set of pads and you will be amazed at how well they improve your stopping distance.
But when do they get hot enough to need stainless steel brake lines?
h:
