Best turbo for a B20b with b16 trans?
Old Apr 17, 2005 | 09:42 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Default Best turbo for a B20b with b16 trans?
It is a b20 it has the b16 trans that is really short geared. I want a turbo that builds fast and that can push 20psi. I have a t3 right now but i cant push anymore boost because i dont have long enough gears. If anyone knows what turbo would be the best for my situation, or what trim.
Old Apr 17, 2005 | 10:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Why not swap out the tranny for a longer geared one like an LS tranny? That turbo is fully capable of 20 psi. You will have to sacrifice either power or spool up if you are going to change turbo sizes.
Old Apr 17, 2005 | 10:17 PM
T72... h:
quick question for you though, why are you running a B16 transmission on a boosted b20?
i figured you might want to stay in boost as long as possible and that B16 trans isnt helping you one bit
Old Apr 17, 2005 | 10:20 PM
Snoopy's Avatar
Snoopy
been there done that
i think a gsr tranny is a nice comprimise between the b16 and ls trannies for boost applications. it's not too short and not too long.
Old Apr 17, 2005 | 10:25 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
I'd go with the LS and maybe some sort of LSD. The longer gearing will help with the gas mileage too.
Old Apr 17, 2005 | 10:33 PM
Civic2Scooby's Avatar
Civic2Scooby
fawk all that b16a = shorter gears shorter gears will always = faster acceleration.....and as far as staying in boot, I dont really see the benefit of ultra tall gears JUST to stay in boost if it slows down acceleration. I just dont see the trade off being worth while...I stay stick with the b16a or as noopy said the GSR tranny for an in the middle ground.
Old Apr 18, 2005 | 04:22 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Originally Posted by b16aEGcivic
fawk all that b16a = shorter gears shorter gears will always = faster acceleration........I stay stick with the b16a or as noopy said the GSR tranny for an in the middle ground.
Exactly
And that turbo will be fine, as long as your b20 is sleeved
Old Apr 18, 2005 | 05:07 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
GSR tranny > LS tranny and that whole staying in boost longer BS. I've used both trannys and the GSR is much faster.
Old Apr 18, 2005 | 05:21 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Screw speed. With gas prices as high as they are, LS > GSR.
Old Apr 18, 2005 | 06:24 AM
westcoaststyle
sporting 26mpg daily, up to 35 mpg highway. h:
