Can't get the pin out now, its about 1/2way through.
Old Apr 17, 2005 | 06:20 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Default Can't get the pin out now, its about 1/2way through.
Should I wd-40 it or something? It sucks that it has a hole in it.
Old Apr 18, 2005 | 02:09 AM
twinring's Avatar
twinring
what are you talking about?
Old Apr 18, 2005 | 05:15 AM
Jafro's Avatar
Jafro
I'm made of meat!
shift linkage pin...
Grab it with vise grips and pull on it. You'll notice it has a groove going through it... you can compress that thing.
Old Apr 18, 2005 | 05:48 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
If you can't get to the top to pull it out, take those vicegrips, lock a bolt into that is basically the same diameter as the pin (small enough to fit into the linkage but not small enough to get stuck in the pin itself) and hammer the sucker home. The vicegrips will let you hold the bolt and swing the hammer without loosing any fingers and it's typically short enough to actually let you swing (most full size punches that would work here are too long to let you swing when the car is only on jack stands). Make sure the bolt isn't important as the vicegrips will typically destroy the threads.
Old Apr 18, 2005 | 06:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
those pins are the biggest pain in the ass. Took me forever to get mine off. I did exactly what "andy" is saying. Found a bolt that fit in there and wacked it with a hammer.
Old Apr 18, 2005 | 06:39 AM
swaggs21's Avatar
swaggs21
Mine came out when I did mine, I got lucky....
Andy is right on this one, makes it pretty easy.
Old Apr 18, 2005 | 07:55 AM
Omniscient's Avatar
Omniscient
I pulled the engine out with the linkage unharmed I got lucky It just came right on out, didn't get jammed or anything!!! My engines out!
