removing OEM side skirts
my bum is on the swedish!
I understand its just a bunch of phillips-head screws and clips, but does anyone have a DIY or a walk-thru? I've heard the bottom clips are a bitch, and I don't want to break anything while I'm taking them off this weekend :rick:
Its a piece of cake. To get the bottom clips out, just pop out the center portion with a flat head screw driver, then pull out the outer piece. Once you get all the clips off and remove the screws on the sides, you just need to smack the sideskirt with a rubber mallet towards the back of the car to remove the sideskirt from the clips that hold it to the body. Here's some instructions in case you need more help:
http://www.handa-accessories.com/civ...derspoiler.pdf
