Bouncing Speedometer needle
blk pin is ground
yellow/ white is to the speedo
yellow/ blue is for power/ ignition
the procedure for testing this is in the stickies under the 92-95 manuals section 11-74. Look it up in there.
i had the same problem.....i looked at the connecting points of the plug in harness. one was green and corroded. i took apart the pins and cleaned them up....worked fine ever since. i also want to add the i also had another problem....turned out to be the igniter in the distrubutor.
I had the instrument cluster out of my 98 Civic yesterday on Xmas, changing a bulb, and I can tell you from the cluster-end, it is wrapped up with the rest of the cluster cables (two big blue/green ones, an orange, green, etc).
William
98 Civic + 03 Pilot
William
98 Civic + 03 Pilot
