Garrett T3/T4 57 trim turbo too big for a civic?
Old Apr 5, 2005 | 12:55 PM
Mario's Avatar
Mario
Originally Posted by ajusaf
since ur so educated then give me the scoop to save me time. so if i want only like 50 hp increase due to stock engine and like full boost by 4k rpm then go with a t25 with .48?
Since you can read, read this:
http://www.homemadeturbo.com/forum/i...?topic=37464.0
Old Apr 5, 2005 | 01:01 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
What to you is full boost? If I wanted to hit 4 psi at 3k, I can do that no problem, but it takes me a bit longer to make 20. So, what's full boost to you?
Old Apr 5, 2005 | 01:20 PM
raiden571's Avatar
raiden571
turning u inside out
i would recommend a 60 trim or super 60 trim t3, those are perfectly sized for our motors. there are tons of applecations tho. 14b's arent bad, turbos from volves and saabs work well. i would saty away from a t25 and anything that size, you might be seeing boost at idle with something to small, and that would suck.
Old Apr 5, 2005 | 01:26 PM
ajusaf's Avatar
ajusaf
well full boost I meant is the psi you controlling. for stock d16 engine i guess the most you can boost is 6psi. at 4k rpm is good for me to have itt boost all 6psi. are there good affrdable turbo kit too bolt in my engine?
Old Apr 5, 2005 | 01:33 PM
westcoaststyle
Greddy and Edelbrock both make good bolt-on kits. The Greddy is now tunable, whereas the Edelbrock is not.
Old Apr 5, 2005 | 01:45 PM
ajusaf's Avatar
ajusaf
any links to those kits? for the d16 i would need turbo, manifold and what about exhaust? this is just for 6-7 psi
Old Apr 5, 2005 | 01:48 PM
westcoaststyle
Greddy: http://www.optauto.com/index.htm?sto...er=TP-11550050
Edelbrock: http://www.wiredspeed.com/store/prod...c=EDL-1500&eq=
raiden571's Avatar
raiden571
:eh: what? ill be running ten here in a couple weeks. whoever told you that is a moron. hell, pat i think is running like 13psi with stock internals, its all about tuning my friend. oh, and build a kit, cheaper and more fun
Old Apr 5, 2005 | 01:50 PM
westcoaststyle
:werd:
Andy (SleeperCivicEX) ran 13 psi daily for a couple years and dyno'd it in at 220 whp. I love internet rumors. :chuckles:
Old Apr 5, 2005 | 02:02 PM
EK hatch's Avatar
EK hatch
I hate ricers
Yeah building a kit would be alot cheaper and it might get you the same hp.
