Question about CTR's and HID's???
I heard the getting HID's with stock headlights are bad b/c the thing that covers the bulbs makes the light glare really bad. Well since the CTR's dont have that thing
would the glare be worse or better? If I decided to get HID's I would not want to retro-fit anything into those headlights.
Originally Posted by 18secFerio
chances are they'll probably blind alot of people. I got flashed simi-frequently when I had my CTR headlamps, and I just had stock halogens
Originally Posted by dawrenn
Damn, thats what I was afraid of. Someone told me I could get casper shields, they said it would help with glare.
however, another thing I've heard is people doing merc/bmw projector retrofits in ctr/sir headlamp housings specifically because they don't have the headlamp bulb reflector. the only problem there is spending $400 on lights just to tear them up, and then spend another $200 on a projector kit
yeah, I've heard asiandoood talk about getting those shields for ctr's in past threads.
Originally Posted by delsoldude
you do not need to tear up $400 headlights, get projectors and HID kit. The kit will use the bulb size that the projectors use
If you want HID's, that is pretty much your only option. Unless you get them from another doaner car and retrofit them to your CTR headlights. Which would require you to pretty much gut them. I did not think you wanted to do that. Or you could do it to a pair of USDM ones, then if you don't like it you are not out the CTR's
