Leaking coolant
Leaking coolant
My car is leaking coolant around the area of the alternator. Im guessing and hoping its the waterpump. Aslo if i have a blown head gasket what signs should i expect. Theres no water in the oil and no coolant in the exhaust. So anyone have any idea what is leaking on my 95 civic EX. Its under and a litte bit to the front of the alternator. And another question. I dont think i can replace it myself if its a waterpump so what price is reasonable from a mechanic for a water pump, timing belt, and tighten the radiator hose clamp????
hey, so that decal dude makes decals, Well i was wondering, i bodyboard cause i live in hawaii and im starting a video company that shoots bodyboarding videos. You think if i have some of them decals made they will stay pretty good on the bottom of a bodyboard. Proffesional bodyboards consist of a fiberglass bottom and it will be in contact with salt water alot.??????????????????
That's what its all about
300-500$ parts and labor. Get under the car and check the weep hole on the water pump, could be that. Loss in compression, white smoke, coolant in the oil, oil in the coolant. Check to see if there is pressure on the radiator hoses. The radiator hose clamp should be something you can do easily....
