Timming Belt Ques
Old Mar 23, 2005 | 08:18 PM
OblivionLord's Avatar
OblivionLord
Default Timming Belt Ques
On this site...
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
It shows a timming belt change walkthrough.
Now my question is on step thats near the beggining which involves taking off the crank pulley. After you loosen the tension on the alternator belt and remove it from the crank exactly how do you take off the crank pully? He skipped that part without getting into detail.
Old Mar 23, 2005 | 09:07 PM
thomas's Avatar
thomas
pew pew pew
well thats the trick see, you can take off the flywheel inspection plate and hold with a screw driver (what we did) or 5th gear stopping on the brake
Old Mar 23, 2005 | 09:31 PM
OblivionLord
I dont quite follow what you mean by taking off the plate and holding it with a screwdriver.
Old Mar 23, 2005 | 11:49 PM
thomas's Avatar
thomas
pew pew pew
the flywheel inspection plate and jam a screwdriver in the flywheel so it dont move
Old Mar 23, 2005 | 11:52 PM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
it's a metal cover that goes over your flywheel to keep shit from getting in there. has 4 or 5 bolts that hold it on there, remove them, then you'll have to wiggle the shit out of it to get it off, and then you just have someone wedge a screw driver in the flywheel teeth, while you rip on the crank pulley bolt.
Old Mar 24, 2005 | 08:08 AM
oscar_425's Avatar
oscar_425
Got V-TEC??
I think this is the best walkthrough for a timing belt change
http://www.hondatuningmagazine.com/t...ing/index.html
Old Mar 24, 2005 | 08:10 AM
honura's Avatar
honura
Seni
Nice!!!
Old Mar 24, 2005 | 05:37 PM
Redcivic's Avatar
Redcivic
One of the original OG's
Get the moroso timing belt wrench if you plan on doing this more than once. The hardest part is learning how to get the engine at TDC.
