overheating problem, fan not coming on
hey guys.. my cousin has a 95 ex and recently its started to have an overheating problem. namely the fan isnt coming on all the time.
sometimes it works, othertimes it doesnt.
its not the fan motor, ive put 12v to it, it runs fine
its not the relay, i swapped it and the AC blower motor relay, and the AC always blows
so im figuring its a sensor somewhere that tells the ECM to turn the fan on.. or a connection somewhere before the relay
has anyone had this problem, anyone have any ideas? thanks!
i had the same problem only mine didnt come on. reason cuz the temperature sensor wasnt plug in correctly. maybe u have a bad sensor. the sensor is located right under the distributor and its the smallest one. its plug right into the block.
late
late
i had a similar problem. i would first replace the thermostate cuz its the cheapest, but i think the problem is the radiator fan switch. its located reight where the thermostate is, and theres a wire coming out of it that leads to the radiator fan motor. i think its abot 40 bucks from Honda. good luck
if you plugged in 12V to the fan and it comes on with no problem then it's probably something between your thermostat and switch. temporary fix it- hook up a relay and aux switch to turn on the fan manually. :thumbup:
damn! you guys are cool, thanks alot for the help, im on alot of boards and NONE of them are this friendly to new guys (especially those gay ass supra guys).. but anyway i just wanted to thank yall for the advice and help! im sure gonna need it as i learn more about my cousins 95 ex, and my friends 90 crx si (which were about to put a dohc zc motor in next week because his stocker blew and its the only thing he can afford right now)
anyway, thanks
oh and if you need help diagnosing turbo problems.. i might have answers so lemme know.
anyway, thanks
martmc
92+ Civic/EL & Del Sol
8
Jan 15, 2008 04:21 PM
doctorChandra
CRX & Pre 92 Civic
8
Sep 20, 2007 11:53 PM
Big Chaze
Engine Swaps, Tech & Tuning
4
Mar 5, 2004 03:34 PM
