No spark....plz help!!!!!!!
Old Mar 17, 2005 | 05:46 PM
sihatch41's Avatar
sihatch41
Default No spark....plz help!!!!!!!
I have no spark in my hatch...b16. I have checked all the modules and relays that i know of and I'm a creek. i have already replaced the ign. coil and module and don't know where to go next. Any advice on any testing or replacing stuff would be very appreciated. Thx
Old Mar 18, 2005 | 07:15 AM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
Does the engine crank but not start? Do you have an aftermarket ignition system? Your getting air/fuel and compression but no spark? New Cap? Rotor? Wires? What ECU? Sorry I need more info to help.
BTW: welcome to HAN!! I hope we can help you fix your problem.
Old Mar 18, 2005 | 08:16 AM
Illegal B16's Avatar
Illegal B16
New Zealand
make sure the coil in the distributor isnt burnt.
Old Mar 18, 2005 | 08:44 AM
Running925's Avatar
Running925
Your Powder Coater
check your engine grounds!
check your spark plugs & wires!
start with the basics & also give us some more info, is the a fresh swap or is this a daily drivin car that just stoped running? Help us help u by giving us every bit of info possible.
Tony
Old Mar 19, 2005 | 12:33 AM
twinring's Avatar
twinring
when you say module do you mean the ignitor?
sure your timing belt isnt broken?
Old Mar 19, 2005 | 08:40 AM
Moso's Avatar
Moso
i had the same problem before turned out it was the distributor module, sometimes refered to as the ignitor, can be fairly expensive and no real good way to test it, try finding one at a yard or if you gotta good friend (like i did ) borrow his dist for a min.
