what makes a CVT tranny special from normal civic tranny?
Old Mar 17, 2005 | 01:56 PM
ajusaf's Avatar
ajusaf
Default what makes a CVT tranny special from normal civic tranny?
i have a automatic in my crx what does cvt offer compare to my original tranny? will a cvt fit all honda engines or only the vtec-e?
Old Mar 17, 2005 | 02:06 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
What it means the consumer, is the CVT is a more efficient transmission than the traditional automatic gear box. That means, more efficient use of the power from an engine through the tranny which means better performance. Or, you can think of it this way: better economy for the same performance.
A transmission must match the engine it's being mated to regardless of if it's manual, auto, or CVT. Or you can find ways to custom mate the two.
Old Mar 17, 2005 | 02:11 PM
ajusaf's Avatar
ajusaf
i need to look i don't thin it will go for my 90 1.5 crx which i might make it manual. I might take take the manual tranny from my hatchback and drp it in my 1.5 crx if it will fit from my 1.6. drop cvt in my hacthback if the CVT tranny fit. my wife prefer automatic the volvo she drives is at 20mpg witthe civic we get like 32mpg
Old Mar 17, 2005 | 02:42 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
just keep it simple and do the manual tranny swap. i think it is a lot more involved than you think it is to drop in a CVT. i dont even think honda made a CVT tranny for the D series. ive only seen it on the civic hybrid and the insight.
Old Mar 17, 2005 | 03:01 PM
ajusaf's Avatar
ajusaf
well the Cvt goes on the hx engine vtec-e isn't that a d series engine?
Old Mar 17, 2005 | 03:50 PM
honda guy's Avatar
honda guy
The CVT tranny is also belt drive so keep that in mind.
Old Mar 17, 2005 | 04:08 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
I would never swap in a CVT tranny. If anything breaks (and it is more likely to on a CVT vs. a normal manual) it will be expensive to fix.
CVT's are beneficial because they have infinately variable gear ratios so you are always in the optimal range of the engine. The down side is that they cannot handle much power as they will start to slip.
