If the clutch is being replaced, but other opportunities are there?
Old Mar 9, 2005 | 04:39 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Default If the clutch is being replaced, but other opportunities are there?
It's starting to look like I'll need a new clutch soon or live with the cold stutter.
Anyways, so I would NOT be doing the job myself, so considering how expensive labor is, what other opportunistic things should I consider replacing/upgrading/fixing while they're pulling the tranny off to change the clutch?
- lightweight flywheel?
- new drive axels?
- LSD?
- check health of the synchros and gears?
- (do they automatically replace tranny fluid with new stuff?)
Old Mar 9, 2005 | 04:53 PM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
- lightweight flywheel? might as well, it would need to be resurfaced anyway
- new drive axels? not unless there's anything wrong with them
- LSD? Would require dissassembly of the trans itself
- check health of the synchros and gears? see above
- (do they automatically replace tranny fluid with new stuff?) tell them to just to be sure
Answers are in your quote. For the LSD, and checking gears and synchros it's not reccomended unless you have grinding and/or bearing noise, or if you just really want that LSD. Tranny disassembly costs many labour hours.
Old Mar 9, 2005 | 05:46 PM
raiden571's Avatar
raiden571
turning u inside out
make sure you have your flywheel cleaned up for the new clutch, i would recommend having a machine shop due it properly and also shave off a few pounds. i was quoted 200 for an install and for flywheel to be resurfaced, but those are friend prices, so im not sure how much it would cost
Old Mar 9, 2005 | 06:45 PM
ManTiS's Avatar
ManTiS
NinJA
- resurface flywheel
- check front suspension components
