95 Civic Ex Wont start In CarThief Haven
I checked all fuses,
Reson for pulling the spark plug wires 1-by-1 was for me to test and see if all 4 spark plug wires were working properly.
(Not sure how I check them with engine off)
car is fine at the moment , just want to get it going
"not worried about a thief stealing my car, worried about my stuff being stolen or vandalized "
Originally Posted by Gin
doubt it's the ignitor, called dealerships said the havent sold one for a fix it problem in over 5-6 years, thinking it might be coil or something else with the ignition.
did you check for CELs?
are you hearing the fuel pump run when you first turn the key to Run?
connect a timing light and see if you have spark (point it at anything then crank the engine)
the coil is easy to check if you have a digital multi-meter (a crappy one from radio shack works great)
Fuel pump is active and fine
No spark what so ever,
Im guessing it might be the coil or one of the wires might be dead running to the dizzy, if someone agrees, please help me find which certain wire off the dizzy to test with a 12volt meter.
then test the ignitior...
