2000 Honda Civic Overheated
Old 06-28-2017, 10:54 AM
regandmeg
regandmeg's Avatar
Default 2000 Honda Civic Overheated
Hello my 2000 Honda Civic has had a belt that has been squealing off and on for a while. Today, after starting my car and driving two miles down the road it overheated. The engine was hardly warm. The thermostat is working properly. Could a belt be the problem? Or should I check into something else?
Old 06-28-2017, 01:33 PM
ChrisS
ChrisS's Avatar
My list of candidates ($ to $$$$):
Coolant level? (Burst radiator or heater hose could mean more $$$ problems if you didn't stop and shut the engine off.)
Radiator clogged up?
Water pump gave up the ghost?
Old 06-28-2017, 01:54 PM
regandmeg
regandmeg's Avatar
Thank you. It was shut off right away. Upon opening the hood there was fluid sprayed inside the hood. How would I check water pump?
Old 06-28-2017, 05:53 PM
ChrisS
ChrisS's Avatar
It's not the water pump.
Either a hose burst or there's a major crack in the radiator's top or bottom (plastic) end caps.
take care,
ChrisS
