Sway Bar Question
Old Mar 2, 2005 | 02:07 PM
93civicsedan's Avatar
93civicsedan
Default Sway Bar Question
I going to install front and rear sway bars soon but am confused about the front. I picked up front civic ex lcas with the stock sway bar and all hardware. To install a front gsr bar what parts do I need from this picture or do I just need the bar and reuse the stock parts? For the rear I got teg rear lca that have the sway bar holes and a itr bar with all the hardware so I think I am fine there. Can someone clarify the front for me thanks.
Old Mar 3, 2005 | 09:10 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
fronts - 10/11 with the bolt (if yours doesn't have it) 3, 4, 30, 31 plus the obvious 1/28/5/18(or 2/27/6/5) combo.
rears - be sure to get some sort of subframe reinforcement or you will eventually have problems.
Old Mar 3, 2005 | 09:20 AM
93civicsedan
Thanks for the reply. I got all those parts you listed I just wanted to know if I can use those same parts with a gsr bar or do I need to get those parts for the gsr bar? Also for the rear do I need #12,13 from this pic.
Im gonna get the a spec racing reinforcement for the rear subframe.
Old Mar 3, 2005 | 10:53 AM
Relic1's Avatar
Relic1
That looks like a mount for the piviot points to me. If you're getting the A-spec rear bar you will have the bar to fasten the mounts to, so no you do not need them.
BTW, let me know how you like the a spec bar. I'm thinking about picking one up myself.
Old Mar 3, 2005 | 10:58 AM
93civicsedan
Thanks. So for the front I can use the civic ex hardware for the gsr bar? Or do I need to get the hardware for the gsr bar? Ill let you know how the brace feels once I install it. Would I have any problems running a stock ex bar up front and the ITR in the rear?
Old Mar 3, 2005 | 12:02 PM
Relic1's Avatar
Relic1
front - the bushing #10 will obviously have to be for the GSR. everything else I think is the same.
you shouldn't have any problems with the EX front bar and ITR rear, maybe a little oversteer, but not undrivable.
