power window help
Old Mar 1, 2005 | 05:01 AM
Raun_31's Avatar
Raun_31
Default power window help
i have an 97 honda civic n i have auto power window but everytime i let my driver side window down it alwayz com off track tha passenger window never do that so can somone tell me whats wrong wit it n give me som suggestions
Old Mar 1, 2005 | 10:37 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
either the window track needs adjustment or it needs replacing.
try adjusting the lower rear point of the track forward a little to pinch the window a little when it's all the way down. If you're at the max of the adjustment and it still needs more, it's time to replace the rubber window track.
Old Mar 1, 2005 | 11:57 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
it might just be as simple as lubing the track. if its binding that could be why its coming off. Youll want to take your interior door panel off to be sure.
Old Mar 1, 2005 | 01:22 PM
honda guy's Avatar
honda guy
This should help. May be a bent regulator to.
File Type: pdf
Old Aug 9, 2005 | 09:18 AM
robert131313's Avatar
robert131313
I have the same problem with the driver's side window coming out of the track. I have a 94 honda civic ex 2 door. I took the door panel off and discovered that the plastic piece that is connected to the bottom of the window where the bolt goes through - broke off! Is there some kinda super glue I should use to glue it back on there?? Has anyone dealt with this?
