Best drag times for bolt on civic?
Old Feb 28, 2005 | 11:12 AM
Josh M's Avatar
Josh M
Well if any of u will be in Omaha on May 23rd...........I'll be there tracking the s2000
Old Feb 28, 2005 | 12:19 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Originally Posted by darth asiandoood
SCCA HPDE :thumbup:
Driving a honda on Sears Point or Laguna Seca was the most fun i ever had.
I thought it was called SCCA PDE. Cause NASA uses that name HPDE.
Autocross Help Page
Old Feb 28, 2005 | 01:16 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
oops..ur right :chuckles:
NASA HPDE... i got it confused with my friend's SCCA SoloII thingy.
Old Feb 28, 2005 | 01:58 PM
goon54's Avatar
goon54
[QUOTE=xsentrixsupra]Ok I'm looking around for what type of times people are getting with this setup.............its not too amazing but just wanted to get an idea of what to expect
just out of curiosity, why u ask if u gots a s2k or a supra?
Old Feb 28, 2005 | 04:31 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
Drag racing a Civic is llike buying decaf coffee - "What's the point?" Drag racing is pretty easy. You just step on the gas (if you have an auto), press clutch in, shift, let clutch out and gas. Do again until you get to end of track.
Our Civics were meant to handle so go autocrossing.
haha. civics weren't meant to handle. they weren't meant for racing, period. they were built as a fuel efficient grocery getter. you can make em do anything though, the possibilities are endless.
back on topic though. you should be able to score at least in the 15's after a pass or two.
Old Feb 28, 2005 | 07:05 PM
Jafro's Avatar
Jafro
I'm made of meat!
Bolt on Civic... yeah... but with which motor?
I know my CX still wouldn't have even turned an 18 with those bolt ons when it had the 8v motor. I removed the air filter and muffler and only managed to get a 19.95 @ 65 mph. Best I could do. 3 passes.
DX motor runs mid 17's in a CX. I'm sure the EX/Si could do what you're estimating. The NA DOHC swaps I've seen around here run 13-14's.
Old Feb 28, 2005 | 08:16 PM
u live in sea level? in AZ, N/A DOHC ( TALKING B16s, B18Bs,B18C-GSR,exluding the type R) are running mid and low 15s, to mid to high 14s. Most people around here have to build a little bit to pass low 14s and lower.
anyways, back on topic, i would say low 16s to high and mid 15s depending on driver and conditions
