Sloppy Clutch Problem
Old Jan 30, 2005 | 08:23 PM
mug's Avatar
mug
Just wanted to update this thread. The clutch is normal feeling now. I had my friend who drives an Integra feel it. He said if feels like his car. I agreed. It is now firming up after about 50 miles. Thanks for all your help guys.
Old Feb 9, 2005 | 03:38 PM
michaelmezz's Avatar
michaelmezz
hey did you bleed your clutch lines correctly, you have to build up pressure and push air out of the lines, if you need a complete write up let me know, i did mine over the winter..
Old Feb 10, 2005 | 07:49 AM
mug's Avatar
mug
I had someone pump it up and on the last push, I'd open the nipple and close it before the pedal hits the floor. This is how I was taught. Let me know if there is a better way.
Old Feb 10, 2005 | 08:19 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
the clutch doesnt work the same as the brake so pumping the pedal wont do anything. all you need to do is push down the clutch, hold it, have someone open the bleeder, close the bleeder, let go of the pedal, check resivoir and refill if necesary, repeat untill no air bubbles.
Old Feb 11, 2005 | 08:08 AM
mug's Avatar
mug
I'll give that a shot. Thanks for the info.
