planning to change stock rims, need assistance with size.
Old Jan 27, 2005 | 08:34 AM
ajusaf's Avatar
ajusaf
Default planning to change stock rims, need assistance with size.
I have a hatchback civic and its stock with 14's. I want to keep the proper tire sizes for fuel economy but want to change the look of plastic hubs to nice rims to make the car look better. Do I keep the same size or go up a little? My main concern is fuel economy not performance. Also which spark plugs work best with the civics?
Old Jan 27, 2005 | 08:47 AM
Kestrel's Avatar
Kestrel
Push to shock!
Originally Posted by WideBodyEK
contrary to popular beliefs,...Axe body spray will not get you laid in an elevator
Get NGK spark plugs, the stock kind.
As for rims, I would say 15's would work well. If you don't want to worry so much about offsets, Honda has 15's available that should just bolt right up to your car.
Old Jan 27, 2005 | 08:49 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
15s would be your best bet if you want to go with performance while still having decent gas mileage. tires would be 205/50/15
Old Jan 27, 2005 | 10:11 AM
teg92's Avatar
teg92
WHAT OK YEAH!
15 or 16 I have 16" rota c8's that im selling let me know if your interested
Old Jan 27, 2005 | 10:12 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
If you have a 92+ Civic the right size for 14s are 185/65x14".
You can go up +1 size to a 15" wheel like a 15x7" with 205/50x15" or 195/55x15" tires.
Autocross Help Page
Old Jan 28, 2005 | 06:37 AM
ajusaf's Avatar
ajusaf
that will not reflect on my fuel effiency?
Old Jan 28, 2005 | 06:52 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
well then if you dont want to add a bigger rim then just go for 99-00 Si or 2001~ EX rims. either those or go for the GSR blades or fat fives. sized 195/60/14 or 195/55/14
Edit: wait.....am i retarded or something or are the GSR rims and Si rims 15?
Old Jan 28, 2005 | 12:11 PM
CivicSiRacer
As long as you keep the overall diameter within specs you should be fine. WHenever you go up in size of a wheel say from 14 to 15 you go down in aspect sidewall height of the tire.
So 185/65x14" would be a 195/55x15", 16s would be 205/45x16"
You will get worse mpg if you go to a heavier rim, but the GSR and Si rims are lighter than I think than the steel wheels like 14s.
Autocross Help Page
Old Jan 29, 2005 | 07:00 AM
ajusaf's Avatar
ajusaf
how much does each rim weight for it to be consider light weight like the Si rims? 15lbs each or 12 etc. ?
Old Jan 29, 2005 | 08:03 AM
copperfox's Avatar
copperfox
nubsos
Fortunately for you, aftermarket wheels that promote fuel efficiency are generally also good for performance because they weigh less than stock. Less unsprung weight is your friend.
If you have a 5th-gen (like me) I would get 15" rotas because they are even lighter than the Si wheels (most of them) and they look fantastic (imho). If you have a 6th-gen civic then I would get either 15" or 16", but I'd probably still stick with 15".
To retain stock size on a 5th-gen with a 15" get a tire that is 195-50-15
To retain stock size on a 6th-gen with a 15" get a tire that is 195-55-15
If I've posted any incorrect info, someone please let me know.
P.S. I have 15x6.5 rota slipstreams and I love them. My tire size is 205-15-15.
