Tie Rod Ends
Old Jan 25, 2005 | 05:44 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default Tie Rod Ends
Ok i have a theory/question. COuld you take the tie rod ends and flip them side to side and from the top to the bottom. IE use the passenger on the drivers side but instead of haveing the nut on the bottom of the mounting point invert it.( nut on the top and balljoint ont he bottom) I would think this would help the steering in a lowered car. Any opinions are welcome, like i said i wonder if this would help or not. Thanks
Old Jan 25, 2005 | 05:55 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
I seriously do not see why not.
Post 97 (pretty sure) Honda discontinued cotter pins on them, so de-threading and falling out would be the only cause for failure that I can see...but what are the chances of that?
If I hadn't changed them just last year I'd give it a shot. But the gains would be pretty minimal, and maybe not even justifiable.
Old Jan 25, 2005 | 07:45 PM
drog's Avatar
drog
No, because the hole and the joint end that goes through it are conical shaped, smaller at one end than the the other.
Old Jan 26, 2005 | 08:30 AM
PDiggityDogg
Im pretty sure theyre not conical
Old Jan 26, 2005 | 04:23 PM
HatchVX's Avatar
HatchVX
Old Jan 27, 2005 | 06:15 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
no you cant. the geometry wouldnt match up and you would immediately destroy the joint on the tie rod. Why would you want to do this anyways?
Old Jan 27, 2005 | 09:08 AM
PDiggityDogg
If you put the left on the right and flipped it, it would be the same geometry.
