Need to pull CEL codes off a 96 Civic
Old Jan 25, 2005 | 10:11 AM
drew935's Avatar
drew935
Laguna Seca circuit
Default Need to pull CEL codes off a 96 Civic
I already have the codes that tell what they are Need to jump the obd2 connector to pull the codes. I forgot how to do that. >? Which pins do I jump again?
Old Jan 25, 2005 | 10:14 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
the best how-to for this... is here
Old Jan 25, 2005 | 10:23 AM
drew935's Avatar
drew935
Laguna Seca circuit
that's good for obd1. 5th gen/Eks are obd2. They have a different plug and have 5 wires. The concept is the same though. Kudos for your effort.
Old Jan 25, 2005 | 10:34 AM
Relic1's Avatar
Relic1
ummm, 5th gens are 92-95(EG), 6th gens are 96-00(EK).
the honda service manual for the 96-00 civic states that the procedure is identical as that listed on the site.
you can also use a code scanner connected to the OBD2 port under the dash neer the left side panel.
Old Jan 25, 2005 | 10:54 AM
drew935's Avatar
drew935
Laguna Seca circuit
well which pins on the connector do I jump then? That connector is for obd1. You know the connector looks different. I know the wires are blue/wht, blue, grey(I think), 2 blacks for gnd maybe.
Old Jan 25, 2005 | 10:55 AM
drew935's Avatar
drew935
Laguna Seca circuit
oh yeah, also I want to pull the codes without the scanner. Just using the paper clip. I've done it before don't remember which pins they are.
Old Jan 25, 2005 | 11:07 AM
Relic1's Avatar
Relic1
quote from the 96-00 service manual.
"the 2P service check connector is located under the dash on the passenger's side of the vehicle."
the same location as the OBD1 cars.
it is not the same wires or connections as the OBD2 connector on the driver's side of the car.
the wire colors of this two pin connector are brown(runs to A10 of the ECU) and black(ground)
Old Jan 25, 2005 | 12:11 PM
drew935's Avatar
drew935
Laguna Seca circuit
ok Relic, I'll look for those. Not sure why that service connector would be there, but I haven't looked yet so I don't know. Thanks for the reply bud.
Old Jan 25, 2005 | 02:50 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
The 5th gen, 6th gen and all the teg years that I've dealt with (94-01) have the same connector. Check the sticky at the top of this section for these kinds of questions in the future. We keep it updated for exactly these kinds of situations.
