Revive my 92 Civic DX Sedan?
Old Jan 19, 2005 | 07:55 PM
nick32's Avatar
nick32
yup, i have the dame D15 im my 93 civic dx coupe....im in the process of swapping in a jdm b16 as we speak. just because the D15 it a hunk of junk to get any sort of power from....its a great motor to get 40+ mpg thought!
im in the process of a partial restoration of my car as well, replacing old rusted parts with new and fixing rust spots on the body and repainting...
Old Jan 19, 2005 | 08:16 PM
bambbrose's Avatar
bambbrose
Originally Posted by Slipjack
Thanks for the reassurance. There is a huge loss of compression on the current D15, and it wasn't taken care of very well by the previous owner. If I do end up making the swap (and I probably will), I'll port & polish the cylinder head, DC 4-2-1 header, catback 2.5" exhaust, then replace all the internals and get some forged pistons, rings, rods, etc. Then drop in a turbo after all that. Of course I'll need suspension and brake upgrades as well. I'll post pics as I progress.
If you plan on building the internals and boosting, don't waste your money on a header. Just save it to help pay for the engine buildup
Old Jan 19, 2005 | 09:56 PM
Slipjack's Avatar
Slipjack
Town Drunk
Good point. Not really much use for bigger exhaust without an aftermarket header though. I could put it off until the rebuild. Will probably do it before the turbo, though.
Still, a B-series is still a bit overkill for the application. Remember, I just want it to be more fun to drive (and gotta' have turbo). Could still get some good performance from a D16. I've considered a mini me conversion, but still so many miles on the block.
If I were to swap in a B18B1 I'd want to go all out and I'd end up turning a hobby project into an obsession.
Old Jan 19, 2005 | 11:28 PM
Nelson's Avatar
Nelson
Administrator
Two cams are more fun
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 20, 2005 | 05:05 AM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
turboD>b16>b18b(nonturbod)>stockD>poop>horsesass>> >>>>>>d15B7
Old Jan 20, 2005 | 06:04 AM
Jafro's Avatar
Jafro
I'm made of meat!
FYI: I replaced my D15b8 with a D15b7. I got a more than a 34hp bump out of it. In fact, it dynoed 90.6hp/90.9tq... It may have made the ride a little TAD bit more fun, and it's amusing at best... but the unfortunate part of it is that it won't make any of it until 4000rpms. A DOHC motor won't give you those problems.
If you boost a D series, just don't go buying a gigantic turbo that you can't spool... a little boost goes a long way with Honda engines because they have higher compression than most factory-turbocharged engines. You won't need a lot of boost to make respectable power. Spend nothing on mods until you want to boost it unless money is no object. Everything on your intake and exhaust will have to be replaced when that happens.
Old Jan 20, 2005 | 06:06 AM
Jafro's Avatar
Jafro
I'm made of meat!
I want to swap a poop covered horsesass in my hatch now
Old Jan 20, 2005 | 08:42 PM
dE.fUsEd's Avatar
dE.fUsEd
that's a stinky swap. i heard it has a peanut cam too. hnoes:
heh
Old Jan 20, 2005 | 09:23 PM
oldskoolcivic's Avatar
oldskoolcivic
yea the D16 is a cheap motor that has potiental, w/o going to the b series and buying motor mounts
Old Jan 21, 2005 | 06:52 AM
Slipjack's Avatar
Slipjack
Town Drunk
That is exactly my logic. That and it's a cheap way to get vtech, which I need.
