Hood Pin Question
Old Jan 15, 2005 | 05:04 PM
dawrenn's Avatar
dawrenn
Default Hood Pin Question
I am thinking about getting hood pins to be on the safe side.
Which ones should I get? Link 1 or link 2?
http://www.robearracing.com/pd_sparco_hood_fastener.cfm
http://www.robearracing.com/pd_sparco_hood.cfm
Old Jan 15, 2005 | 05:21 PM
Kai's Avatar
Kai
Rotorphile.
The second slide-pin type, if it's between the two.
That is, if the car has a carbon fibre or fibreglass hood that actually needs them.
Old Jan 15, 2005 | 05:26 PM
dawrenn's Avatar
dawrenn
It does have a Carbon Fiber hood:
How do I install the pins? What do I do to put the holes in the hood? Is there any kind of write up on how to install them?
Old Jan 15, 2005 | 05:55 PM
dawrenn's Avatar
dawrenn
Do these look like good hood pins or should I just get the ones in the second link? These are from Ebay:
Old Jan 15, 2005 | 06:10 PM
Kai's Avatar
Kai
Rotorphile.
I'd stick with the sparcos.
It's simple. Locate a spot on the rad support for the posts. Drill holes and install them. Mark where they hit the hood and drill two more holes. Screw dow the latch plate and adjust the posts for proper height. Close the hood and you're done.
Old Jan 15, 2005 | 06:18 PM
dawrenn's Avatar
dawrenn
Does part of the latch plate come up? how do the latch/unlatch?
Old Jan 15, 2005 | 06:19 PM
Outxider's Avatar
Outxider
X-Motoring
:werd:
i jsut got my vis cf hood and got the sparco hood pins along with it. i will never run any lightweight hood, cf or fiberglass without pins or locks. i have used sparco pins before and they work very well. my friend decided to save some bucks and got some cheapie ones, the acutal threaded pin, broken in half.
Old Jan 15, 2005 | 06:23 PM
dawrenn's Avatar
dawrenn
Originally Posted by Outxider
:werd:
Do you have them installed? Were they hard to install? Any pics? I am kinda confused on how they work. Can someone explain.
Old Jan 15, 2005 | 07:00 PM
Kai's Avatar
Kai
Rotorphile.
The long posts with the eyelets stick out of the radiator support and though the hood. The pins slide forward into the eyelets in the posts, and the loop flips over to keep them from backing out. The pin is attached to the latch plate so you don't loose it, as is possible with other designs. It's pretty simple, you'll understand once you have them in your hands.
Old Jan 16, 2005 | 08:27 AM
dawrenn's Avatar
dawrenn
I figured out how to install them. All I needed was a closeup picture of a hood pin:
Which was do I install them. They way in the above picture or like this:
