honda oil filter wrench? any comments?
Old Jan 10, 2005 | 06:12 PM
asiancivicguy's Avatar
asiancivicguy
Default honda oil filter wrench? any comments?
If i used the OEM Honda oil filters do i have to use their filter wrench since I was checking out advancedautoparts.com and they listed the wrench as "loaner from Honda"? Also is 5w-20 (in my case Mobil 1 0w-20) too thin? Should I go with 5w-30? If it affects the decision of which viscosity i use, I live in Florida.
Old Jan 10, 2005 | 06:49 PM
Redcivic's Avatar
Redcivic
One of the original OG's
Don't use 5W in Florida. The temperature range is not as good for hot weather. Also, use your hand, you don't need a wrench.
Old Jan 10, 2005 | 07:42 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I have one of those black plastic filter wrenches from Pep Boys. Just incase the filter is too tight. I put mine on hand tight, but as the heat expands and contracts the filter it gets a little tighter on the threads.
Autocross Help Page
Old Jan 10, 2005 | 07:50 PM
oldskoolcivic's Avatar
oldskoolcivic
i work at a shop.. just use your hands, its alot easier. if u cant get it out, wipe all the oil out of the filter and your hands.. it shouldnt be that hard.
Old Jan 10, 2005 | 08:46 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Bought one of these at Pepboy's a few years ago and haven't never once regretted it.
It will dent and destroy the filter as you clamp down on it but you just throw them in the garbage anyway. I just tighten them by hand but I typically can't get a good angle on the sucker to loosen them by hand.
Old Jan 10, 2005 | 08:49 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
So you're saying he should use 10W?
As for the wrench, I found out the hard way that (when you can't use your hand because someone put it on too tight) that the end cap wrenches are only compatible with the filter that it was designed for. If you want a general purpose filter wrench, get the one that looks like a looped nylon (like a seat belt) strap connected to a squared rod with a small hole through it. This wrench wrappes around the stubborn filter and you wind up the slack onto the rod. Then you stick a screwdriver through the hole and twist. It's also good because it allows you to get into tight spaces with it.
Old Jan 10, 2005 | 09:13 PM
taz77's Avatar
taz77
Old Jan 10, 2005 | 10:29 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
can you get a good angle to get to the filter with this wrench on your 98? i have a really hard time getting anything in there cuz theres no room on my 96.
Old Jan 11, 2005 | 12:25 AM
chimchim's Avatar
chimchim
Ooo... taz77's wrench looks adjustable and you use a socket wrench on it. If you've got some nice socket wrench and extensions then that looks like a great one to use.
I've never seen it before. Where can I get one?
Old Jan 11, 2005 | 06:01 AM
Redcivic's Avatar
Redcivic
Yes, use 10W. The if you don't have a filter wrench just jam a screw driver through the filter and twist it off. Or maybe work out a little so you can gain enough strength to take an oil filter off.
