H&R Springs and KYB GR-2 setup????
Old Jan 9, 2005 | 05:51 PM
Joshcivic00's Avatar
Joshcivic00
Default H&R Springs and KYB GR-2 setup????
now, i think i have decided to get this setup, the H&R springs lower .75 inches front and back, can anybody help me out with this saggin issue, the only thing that is holding me back, is how much will springs sag, How much will H&R sag????
please help!!
Old Jan 10, 2005 | 01:33 AM
Brad's Avatar
Brad
wooo nascar!
H&R springs don't sag. they do settle slightly after a week or so. you might get one full inch of lowering out of them with the H&R OE springs.
Old Jan 10, 2005 | 10:15 AM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
I have H&R OE's with KYB AGX's (CORRECTED) on a 97 EX. They seem to have settled around a .75 to 1.0 drop, but stupid me I forgot to measure the "before".
Even with the < 1" drop, the rear WILL need a little camber correction. I used one washer spacing on stock UCA bolts. The alignment still came out with a negative 1.4 degree camber. ("within spec")
Old Jan 11, 2005 | 04:26 PM
m735is's Avatar
m735is
I'm running that setup and have about 20,000 miles on it. About 16,000 with the current tires. I have no rear camber problems, the tires are wearing even and it did settle to about an inch drop. I've got about 60,000 on the rear shocks, front were new with the springs. I feel that the rear shocks are shot because it doesn't take holes or large cracks very well. Not a bad ride - I drive all day on crappy roads. At that price I will be putting new ones on soon. I also have poly trailing arm bushings but I don't think that has anything to do with the no noticable negative camber. 13" wheels with 185/70 tires for winter.
Old Jan 11, 2005 | 08:07 PM
96Civic_Coupe's Avatar
96Civic_Coupe
Assistant to the manager
do eibach springs sag? im thinking of getting sportlines
