Compression question
Old Dec 19, 2004 | 09:10 PM
IcY's Avatar
IcY
Default Compression question
i have a b18c (si-g) motor in my eg and i wanted to know if the higher Compression the more hp it will put out... also how safe is it to run 12.0:1??
thanks
Old Dec 19, 2004 | 09:23 PM
shifty35's Avatar
shifty35
Absolutely, the higher the compression the more power it will make. 12:1 should be fine on 93 or higher octane, if you tune the timing right. Octane is knock preventer, so the higher the octane, the higher compression/more timing you can run. On race gas, people commonly run 13:1 and up.
Old Dec 19, 2004 | 09:26 PM
IcY's Avatar
IcY
will going from 10.8:1 to 12:1 make all that more power though?
Old Dec 19, 2004 | 09:31 PM
twin3037's Avatar
twin3037
yes espaiclly if you have everything else like bigger cams ported head free flow exaust and tunning tunning tunning
Old Dec 19, 2004 | 09:33 PM
IcY's Avatar
IcY
how exactly do you "tune" your motor after your done.
i have ctr cams in it right now
Old Dec 20, 2004 | 07:30 AM
shifty35's Avatar
shifty35
Hondata/Uberdata/AEM EMS or something + wideband + dyno time.
Old Dec 20, 2004 | 09:38 AM
raiden571's Avatar
raiden571
turning u inside out
you might wanna run someting better then pump 93. myabe go 50/50 with sometyhing higher. at Nelson Ledges raceway cars with compression anywhere around that usually run 50/50 with 91 and 109, you might have a rougher idle as well, and tuning is your best friend.
my opinion, all motor is gay, go turbo. more power, more reliable
Old Dec 20, 2004 | 10:04 AM
Kai's Avatar
Kai
Rotorphile.
12.0:1 is too high for street use, IMHO. That's at the limits of street gas.
Old Dec 20, 2004 | 11:34 AM
raiden571's Avatar
raiden571
bow to Kai bitches
