diagnostic mode?
Old Dec 20, 2004 | 12:17 PM
loctoday's Avatar
loctoday
Default diagnostic mode?
hi, where my intake connects to the intake manifold, there is a screw allowing you to change the idle..which im guessing is more or less fuel...if i try to change this can i do it in normal mode or would i have to put the care in diagnostic mode? and if so how would i go about doing this? and another question how do i go about reseting my ecu?
Old Dec 20, 2004 | 01:18 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
that screw is adjusting for more or less air bypassing the TB.
You can adjust that screw in non-diagnostic mode. But resetting the ECU is recommended after doing it. Also after adjusting the Idle screw, checking the ignition timing is not a bad idea.
placing the ECU in Diagnostic mode - with a 92-00 you jumper a plug under the dash just behind the glove box.
Resetting the ECU, pull the backup fuse in the under hood fuse box with the car off and key out. Leave the fuse out for a few minutes, plug it back in and start the car. It's best to let it idle for 5 minutes till the car gets warm to let the ECU relearn everything.
